decoc182
Gasket Help, Drive Belt Help
decoc182
Hi guys, sorry to bother you again, which headgasket set would you reccomend for and xu7jp4 with an RS head? Im not sure wether to use the xu7jp4 kit, or the xu10jp4-rs kit
The same query goes for the timing belt kit?
This engine came with A/C and Powesteering pump which have been removed, so I need a simple belt that runs from the bottom pulley to the alternator. Any suggestions?
I will get some pics of the belt problem tomorrow.
Thanks guys
use the JP4 kit, the bore of the XU10 headgasket is too large, the 7JP4 kit uses different tensioners to the 10J4R too.
as for the auxillary belt that's trial and error, measure the length required and see what the local motorfactor can supply.
decoc182
Nice one mate.
Thanks :unsure:
