johnnyboy666
Part No. Request
johnnyboy666
does any body know the part numbers for the following badly explained items
-306 rear arb end plate rubber bit that goes round the shaft type bit of the end plate ( i guess its a seal?)
-205 rear arb end plate soft washer-esque thing that goes between the surface of the trailing arm and the end plate.
if that makes sense :unsure:
hopefully somebody will know what im on about
thanks
john
Judging from Servicebox, the 306 ARB rubber bush is 517910 and the foam endplate seal is 517403
