Galifrey
[engine_work] Sleeper 1.6 Project
Galifrey
Good to hear :D
Started first turn of the key again today ;)
Galifrey
Well done Mark, good to hear. :)
Was optimistic has gone again, only cold starts tho, so temp sensor may be faulty, will replace and see.
hman205
Did you fix it in the end ?
Galifrey
Yeah just a dodgy connection to the temp sensor all is fine now ;)
Galifrey
Yeah just a dodgy connection to the temp sensor all is fine now :huh:
Think I spoke too soon, now it won't start, cant get a spark, and the plugs are dry so suspect no fuel, sounds like crank sensor to me?
... or the fuel pump relay, which also powers the ECU etc.
Galifrey
Fuel pump is priming when first turned on, but not after that, indicating the fuel isn't being used up.
That was why I thought Crank Sensor
that's the logic I'd use, thankfully a cheap enough and common part :huh:
Galifrey
Yup, Grabbed one off the bay of e for £17 notes delivered pug genuine :lol:
hman205
I have a spare we could test with if you want to borrow it mate
Galifrey
New sensor fitted, started almost as soon as the starter engaged!
Interestingly the new sensor looked like a higher quality item, made by Siemens, hopefully won't need to change one again!
Galifrey
Due to needing a motorway mile muncher, this is gonna have to be sold soon :)
CTI STU
Due to needing a motorway mile muncher, this is gonna have to be sold soon :(
To me :) and I cant wait :blink:
CTI STU
Its now mine and I LOVE it, bit of a pain to start some times though, but Mark has told me its just the temp sensor so Ill get one sorted asap
Galifrey
If only the BMW was as problem free
:mellow:
