Silky
Brake Switch Wiring
Silky
I was trying to get the main part of the dash in over the wekeend, all sort of went ok, took a while to get the wiring routed properly and I've not taken a 205 dash out before so putting one back together was a bit blind.
One problem I have not solved, I can't find the wires which are for the brake light switch on top of the pedal, I can't find any plugs which look right.
Does anyone know where they originate from and what colour they are so I can try and trace it ?
alync406
I am fairly sure the wires are 1 grey one and 1 a kind of violet colour.It is just a small black two pin connector.1 wire comes from the fusebox,at the glovebox and then the other wire goes to the back of the car.
