McDude
Door Pins
McDude
Like many on here, I suffer from a sloppy hole - a sloppy door pin hole that is.
Having done a search I saw a handy little bodge where someone (sorry I cna't remember who it was to credit them) had made a bush out of a bit of thin sheet steel (an SMA can if I recall!!!). I might try this as I have fairly new pins, but the door still sags.
My question is: how do the actual pins come out? Are they an interference fit? Or is there a hidden grub screww? or??? Just tap them out with a hammer?
Any other fixes would be welcomed.
early pins are just a roll pin that you knock out, late pins are threaded with a torx head.
McDude
Thanks Dude.
I have little plastic end caps on mine - I'll prise them off and see if they have anything underneath. If not I'll get out the Birmingham Screwdriver.
plastic caps would be the early type that's a roll pin :)
djinuk
how exactly do you use the sleeve btw ?, do you just glue it around the inside of the hole ?.
McDude
Good question fella - truth is I don't know. I'm going to try and bodge it by making my own bush. I'm thinking that it will hold in place as it really has nowhere to go.
djinuk
hmm, maybe stew at baker bm could machine up some sleeves for the 205's so taht we can drill out the hinges to a large dia , and then we can use a sleeve to bring it back to the perfect size.
Simes
You can put new pins in or drill out and use a larger bolt.
There is actually a widely available special tool to remove the roller pin type.
