marsy
Drivers Central Locking Motor Wiring?
marsy
My 205 gti 1.9, drivers central locking motor has 5 wires coming out from it, 2 are connected via bullet connectors into 2 wires that run down the side of the door. The other 3 are not connected to anything. I also have a connector block with 2 wires coming from down the side of the door connected to it. But no were for it to be connected too on the motor?
Im starting to wonder if someone has potched with it in the past or maybe changed the motor?
My central locking does not work on the car.
CosKev
All 5 should be connected :)
The pass side has less wires,because its not a switch fitted to pass side,its just a motor B)
Drivers side is a switch to operate central locking,and a motor to lock door :D
