WooDooUK
Single Braided Brake Hose
WooDooUK
Hi All,
Due to me being an idiot, I Have accidently clouted the end of one of my goodridge hoses it has now started to leak. :mellow:
Is it possible to buy the hoses seperatley any where? I dont fancy making one up myself due to it being a quite important part of the braking system. :P
Oh its for a 1.9 front caliper if that makes any difference.
Any ideas?
Cheers,
speak to Miles, would imagine he can make one up for you as he does them himself.
I think I may even have a odd Goodridge one spare, PM me if intrested
mrswampy
I can also supply single lines
MerlinGTI
Hi-Spec in dartford will make you 1 up, they did mine. Works out about £15 per hose (+VAT) IIRC :ph34r:
I bet you can, I doubt you have any product liablity insurance thou :ph34r:
mrswampy
The company that make and supply them do though!
And the line from hi spec the other chap got would of being made by them aswell, as they supply All the lines for there kits.
As ive said before to another user be very careful miles what accusations you fling with out the proper knowledge of what i supply.
I didn't think I did unless your putting words into my mouth :P
Can you confirm then about your Fuel line's to set the fact straight
mrswampy
And the fuel lines have exactly what to do with brakelines?
Both supplied by different companies in different specialisd areas.
End of.
Ive not put any words in your mouth but i do have hard copies of comments someone else has made about them just so they cant deleate records.
Said person always promotes your products whilst summising wrongly over what i supply.
He may have no connection at all to you but he has being told the same.
Guest
