Andy_C
Rear Bump Stop Removal & Replacement
Andy_C
Is this an easy job? RHS is missing completely and just bought a set form woodsy here so will do both sides. Question is how easy a job is this and is there a guide anywhere?
Thanks chaps.
Hardest bit is usually getting the remains of the rusted bolt out of the chassis rail. With this done you bolt the steel cup up, then fit the rubber buffer to the cup, it will lever into place reasonably easily with a flat blade screwdriver.
Andy_C
How would I remove the bolt? Assume captive inside the chassis rail? And how do I then fit the replacement?
