floodys
406 Master Cylinder For 205 With 6 Brakes
floodys
I've had a quick search through but just want this info, i need a 406 m/c for my 205 with 6 brakes.
1. is it a 406 m/c NON ABS? (reason being non-abs because it has 4 outlets of m/c?)
2. Do i need to adjust the push rod thing in the servo before fitting?
3. will the 205 resivor fit the 406 m/c or will i need a 406 one!! lol
Thanks very much, and if there is anything else i need to get or to do before i fit it can you let me know!!!
mickie
1, yes
2, no
3, yes
no, search more you lazy get
Edited by mickie
floodys
lol, problem as people have said before with search is that if you ask basic question like the one i have about brakes, you get very in depth answer instead of what you did which is straight forward!!! lol
Retro Pug
Just a quick note to say I did need to adjust the rod a little before travel was acceptable. :ph34r:
ravydavy
I have the said item your after. And it's only done one trackday. I've changed to a compbrake pedalbox so this is spare. Pm me if you want it.
David
Veero
I didn't need to adjust the travel. Also it's better to use the 406 reservoir as it fits on the M/C with a slide pin whereas the 205 one is old and is just held in with the force of the seals. If you can't find one my local breakers had one, I may be heading up there soon so let me know and I can get it for you, complete with reservoir.
ravydavy
I disagree. When i changed the reservoir over the force required to put it into the seals was crazy. it took all my strength and that was with a bit of oil smeared on the seal. that reservoir will never come out of that seal in a month of sundays.
David...
P.S i didn't need to adjust the travel either it was spot on...
