jason7579
Side To Side Movement In Front O/s Wheel
jason7579
Holding my front O/S wheel and giving it a liittle shake there is quite a lot of play in it, I have jacked the car up and didn't really notice any play when rocking top and bottom.
Would this be the bearing? Or something else. I am not hearing any of the usual noises you get when the bearing has gone.
If it is the bearing is the hub nut socket 35mm for the 1.9 GTi? I did my front bearing when I had a 1.6 and the socket I have is smaller than the 1.9 one.
tagy
If it was the bearing there would likely be play when rocking the top and bottom of the wheel also. I would try to look behind the wheel while you or someone else rocks it to see/feel what is moving.. track rod, Wishbone etc
yeah the 1.9 hub nut is 35 mm.
jason7579
Thanks.
Had a better look and I couldn't see the track rod moving but where it connects to the track rod end there was definite play.
I'm not too good at whats what so I will take a picture and try to show exactly where the play is.
gti-si
Is the locknut tight?
jason7579
Something I'll have to check but the TRE rubber doesn't look too great anyway and for the sake of a few £'s I may as well replace it for a nice shiny new one. I need to go to Peugeots at the weekend as I have to pick up an O-Ring for my Distributor.
It seems like another week another part at the moment :rolleyes:
jason7579
Quick update, new TRE's fitted on both sides and the wheel now seems fairly solid. Now thinking about replacing droplinks to see if that will sort out a couple of noises at the front. Along with a new thermostat - bumpstop - heater resistor - the list goes on...
