andyjstone 6 Posted August 10, 2009 I'm cleaning up an old pair of 1.9 hubs I bought off Baz and I have two questions: 1. Can I just use normal black engine paint? 2. One of the bearings has some play in it so I might as well change them both while I'm at it, is this easy to do or does it require any special tools, etc? Share this post Link to post Share on other sites
EdCherry 34 1 Cars Posted August 10, 2009 1. Can do, should last well too. 2. Just a press as far as im aware. Share this post Link to post Share on other sites
andyjstone 6 Posted August 10, 2009 2. Just a press as far as im aware. So how do you get them apart to start with and if I don't have a press is it worth getting one just for this or is there someone I can take/send them to? Share this post Link to post Share on other sites
EdCherry 34 1 Cars Posted August 10, 2009 Id get them down to garage if they are bare, presses can be a fair wad of cash for a one off use so no point in forking out for one. Miles will be able to do it for you pretty easily. Share this post Link to post Share on other sites
Daviewonder 533 3 Cars Posted August 10, 2009 you dont need a press just hit the old one out with a big socket and a club hammer then hit the new one in using the outer shell of the old bearing, a piece of wood and the club hammer. Share this post Link to post Share on other sites
andyjstone 6 Posted August 10, 2009 you dont need a press just hit the old one out with a big socket and a club hammer then hit the new one in using the outer shell of the old bearing, a piece of wood and the club hammer. OK, sounds good to me, and where's the best place to get a replacement bearing kit? Share this post Link to post Share on other sites
Daviewonder 533 3 Cars Posted August 10, 2009 You could go direct to peugeot but i have no idea how much they charge, ive only ever used BRT bearings from my local motor factor and ive never had any problem with these. You would probably be looking at about £15-£20 a side Share this post Link to post Share on other sites
Miles 331 1 Cars Posted August 10, 2009 Don;t use GSF on these as the bearings are not that great, SKF bearing's are a must for the Front' A press is a must, you cannot hit bearing's in or on as it can damage them. Any Garage should be able to do this but you can always sent it to me and I'll swap them over at no cost as it doesn;t take long at all PS, The lower ball joint is the Wishbone, Needs a complete unit again find a Motoquip dealer as they are OE Pug items which are hugly better than anything else Share this post Link to post Share on other sites
andyjstone 6 Posted August 11, 2009 Don;t use GSF on these as the bearings are not that great, SKF bearing's are a must for the Front'A press is a must, you cannot hit bearing's in or on as it can damage them. Any Garage should be able to do this but you can always sent it to me and I'll swap them over at no cost as it doesn;t take long at all You are the man - I will get the bearings in and send them down to you - I've found some SNR kits, are these no good? PS, The lower ball joint is the Wishbone, Needs a complete unit again find a Motoquip dealer as they are OE Pug items which are hugly better than anything else Thanks will get them. PPS Did you get the exhaust pics I sent you? Share this post Link to post Share on other sites
Alan_M 66 1 Cars Posted August 11, 2009 Yeah, don't use the hammer technique. Both my 2nd hand hubs with newish bearings in had bent caliper lugs, probably caused by smacking an unsecure hub far too hard. Use a press, but beware the eyes of the circlip can snap off......... Share this post Link to post Share on other sites
pugpete1108 62 1 Cars Posted August 11, 2009 (edited) A press is a must, you cannot hit bearing's in or on as it can damage them. i have done both my fronts with a big hammer and they are still good after 4 yrs service, as long as you get only the outer race its ok. i found a few short sharp blows with a club hammer and a socket that sits on the outer race works well. but obviously if you can get hold of a press its far easier to get them out without damaging the hub Edited August 11, 2009 by pugpete1108 Share this post Link to post Share on other sites
Paul_13 212 1 Cars Posted August 11, 2009 Andy, theres a place in Hurst on the Grange farm industrial estate that can press the bearings in and out. He started his business selling 205 GTI's. Know his sh!t Share this post Link to post Share on other sites
andyjstone 6 Posted August 11, 2009 Andy, theres a place in Hurst on the Grange farm industrial estate that can press the bearings in and out. He started his business selling 205 GTI's. Know his sh!t Cheers for that, I'll give them a go - there seem to be a few on Grange Farm, do you know if is Autotec, Berkshire Autos, Auto Trans or RPM Mechanics???? Share this post Link to post Share on other sites
davemar 16 Posted August 12, 2009 The hard bit can be getting the circlip out. I recently did mine, and it was so rusted in it was indistinguishable from the hub. The whole thing had to the heated until red and really butchered out. Once the hub was hot, tapping the old bearing out was a bit easier. If the ball bearings and inner race come out (which is possible if the plastic gets knackered) there isn't a lot of surface on the outer race to press against which can make it a lot harder. 20 years of rust and hard wear can make a simple job a lot harder. Share this post Link to post Share on other sites
johny105_y2k 1 Posted August 17, 2009 i used a vice & socket to press the bearing in, nice steady pressure applied all the way home., smashed it out with a hammer. davemar: i always thought it was a big nono to use substantial heat on a hub.????? Share this post Link to post Share on other sites
