Atari Boy
Gauges Instead Of Stereo
Atari Boy
I want to fit some gauges to my track car, the stereo is long gone and currently I have a planking plate instead.
I plan to put the gauges there instead, I have seen THIS on ebay, which I like the look of, the question is how would it will stay in place? I am not a fan of glue everywhere. My current blanking plate has a rear bracket so it is effectively pulled into place, which works great.
Is this the best method or if not what are other doing and has anyone used such a cover?
Jonny
EdCherry
My workings show the 2 1/16th holes are 52.38mm... now would this be standard size for 55m gauges or what? im not sure.
Personally mate id just buy your gauges, buy yourself some more material and save yourself some money as that is bloody expensive.
tagy
I used something like this to mount some gauges in the radio space. I just clips in, but you might want some glue or something to hold it firmly.
The problem I had was with this position you cannot see the gauges at a glance and probobly worse with a helmet, so I moved them up to where the where the air vent was. Like so Using a flat 3x gauge holder from ebay then cut to size. This is a much better position now I can see the gauges quickly.
Only got oil and water temp at the moment but might add oil pressure there also.
52mm is the standard size I think.
All Praise The GTI
can you remember how i done mine jonny?
i just made the same as those with some plastic and a hole cutter. wasnt very neat 1st time im going to redo it soon
nat
Atari Boy
nat
I didn't realise yours was DIY, it looked good. I think I will get the hole cutters out.
Hmmm, WHY? they're out of eyesight down there, there's a perfectly good set right in front of you, ok they may not be quite as accurate but they're good enough to tell you something is drastically wrong, and saves you cash :lol:
The only extra one IMO that a 205 would need additionally to the standard ones is a Volt meter.
