Guest Le JC
A Better Ignition Coil
Guest Le JC
Hi,
I would like to know what is the better ignition coil to fit on a 205 GTi XU9JAZ stock
Any idea ?
MSD 8231
ACCEL 140008 ?
Is the MSD coil a direct replacement for the 205 coil? The reality is the PSA engineers probably matched the coil saturation time with the ignition module. So changing the coil may in fact give less spark performance and/or over heat the ignition module. Unless you have the ability to put an oscilliscope on the coil and watch it's saturation time, I'd probably stick with a standard coil.
An alternative is to change to an intelligent ignition module, such as the Bosch 008 (or equivalent), which will optimise the saturation time for the coil being used.
Edited by petert
If the rest of the engine is standard, I'd personally fit a standard one, as spending money on a fancy one will most likely net no noticeable gains.
Guest Le JC
this ref ? Bosch 1227 022 008
Plug and play or need I to re wire it ?
That is the one. You may need to add another earth wire. I'll check.
wardy18
hi
ive been wanting to look into this too for my hillclimb 205 currently running standard ignition apart from a H&H dizzy and Denso Iridium Sparkies!!
i wouldnt even know where to look when it comes to getting an uprated coil, what do you look for???
thanx
Guest Le JC
If a Bosch 1 227 022 008 suit with an upgraded ignition coil like a MSD blaster or similar ACCEL, it's enough for me for my little upgraded 205 :wub:
Waiting for petert if he could say us how to do that. :)
sub205
If a Bosch 1 227 022 008 suit with an upgraded ignition coil like a MSD blaster or similar ACCEL, it's enough for me for my little upgraded 205 :lol:
Waiting for petert if he could say us how to do that. :wacko:
before thinking about a replacement coil i would convert the whole engine to wasted spark / dual coil. this is much more effective as it gives the coil twice the time to charge.
