edbar 6 Posted July 24, 2009 got a set of 405 mi16 rims with the car just wondered if they are the same offset etc as gti speedlines? Share this post Link to post Share on other sites
jimistdt 1 Posted July 24, 2009 The 15" ones? According to this thread the mi16 is ET29 the Speedlines' ET19 - a 10mm difference. http://forum.205gtidrivers.com/index.php?showtopic=20908 I have a set I'm toying with the idea of re-furbing them and I've read that they should be OK on 1.6 hubs, but will need spacers on a 1.9 set-up. Share this post Link to post Share on other sites
welshpug 1,645 Posted July 27, 2009 they fit on a 1.6 with 3mm spacers, though dependent on the tyres you use you may need more, or no spacers. Share this post Link to post Share on other sites
pugtop 0 Posted August 4, 2009 As Welshie says they will fit a 1.6 with spacers! He knows this coz I have them on my rally car as road wheels. I have 3mm spacers at the front and the wheel stil catches when on full left lock and reversing and I have 5mm spacers on the rear , the wheels are fitted with std spec 185/55/VR15 Pirelli P6000s. I use std 1.6 wheels without spacers for rallying! Share this post Link to post Share on other sites
Chris H 10 Posted August 4, 2009 tried a set of 15" MI16 wheels on the rear of my 205 with a 309 beam, the tyres rubbed on the beam....would clear with a spacer, fitted fine on the front though, with 1.9 brakes Share this post Link to post Share on other sites
