si_03
Sunroof Drains
si_03
hi, i have tried searching and could not find it, i was wondering were the drains are for the sunroof and if the are blocked and need replacing hows easy it is and what parts are needed
cheers si
Anteas
cheers si
i could be wrong but i thinck these come out behind front wings so ud have to take your wing off mate
si_03
no i got wet rear footwells so persumin it is the rear drains
chrisj21
More likely to be the rear window seals, try soaking them in hot water then stretching them out before refitting, they shrink over time.
If it is the sunroof the drains come out in the rear wheel arches iirc. Have a look under the arches/ rear of the car you should spot the two tubes. Maybe a blow out with an air compressor or a jet wash may clear them.
Chris
