jerseypug 1 Posted July 18, 2009 just pulled apart my 3rd beam now and they all have the same problem. the outer bearing has indented into the beam shaft. you can see where the bearings have been seated and the marks are quite deep about 1mm. is there anything i can do about this or do i keep buying beams untill i find a good one. idealy i would like to fit gti6 hubs and shafts but am having problems getting them Share this post Link to post Share on other sites
jord294 89 Posted July 18, 2009 chances are most drivers side shafts will be excessively worn are you saying that the passenger side is aswell? if so, your best bet would be to contact miles on here, and get some brand new shafts Share this post Link to post Share on other sites
jerseypug 1 Posted July 18, 2009 chances are most drivers side shafts will be excessively worn are you saying that the passenger side is aswell? if so, your best bet would be to contact miles on here, and get some brand new shafts yes it is the drivers side, why is that? how do the shafts come out of the arms? Share this post Link to post Share on other sites
jord294 89 Posted July 18, 2009 if you think about it, which side of the car carries more weight? the shafts can be pressed out using a hydraulic press one of which i have, and is the best money i've ever spent through ebay Share this post Link to post Share on other sites
