EdCherry
Leak
EdCherry
Well I have a leak,
Drivers Side Footwell.
The Wider Picture
Not coming from up there
Starts here... no hole im worried.
Anyone had similar or point me in the right direction of where its coming from?
Edited by EdCherry
Scuttle?
richsmells
windscreen seal? I found my glovebox full of water and the passenger foot well flooded. I filled a couple of gaps in the windscreen seal with silicon and that sorted it.
... :ph34r:
Ed, if you've no trim in the car, get some food colouring, mix with water, then run it into one possible leak source point at a time and see if it appears at your place.
EdCherry
Good idea tom, will give that a go. Just a bit worried about that area at the minute will get some pictures of why later.
SurGie
I had a bit in that area on my old gti and found that the bulkhead
to inner wing seal was partly missing and the water drizzled down.
Henry 1.9GTi
Ive got the same on the paseneger side. Please do let me know when you find the root cause -_-
DamirGTI
Id say , if it's not coming from the top i.e. windscreen , then it's from the gap where the inner wing panels are spot welded together .. now i dunno how we call this area precisely so i'm gonna do what i usually do .. will stick a few pics :lol: :
I've been welding this wing areas on both of my cars , this flat outer panel is spot welded to the inner wing and the gap sealed with the seam sealer .. which is often in cracked state .. :
note the top drain hole marked with red circles
panel gap sealed with seam sealant
.. so with a bit of rain and parking at an slight angle the water goes from the bulkhead top , from where it usually collects during the rainy day , down the drain passage past the seam sealed wing area till the bottom of the sill corner where it pours out .. :rolleyes:
Edited by DamirGTI
EdCherry
As I thought damir! now do I take the wing off.... decisions decisions.
DamirGTI
Try as Tom said , with the food colouring mix :rolleyes: park the car at an angle , lift up the floor carpet a bit and ask someone to pour the water mix (or simply stick a garden hose ..) into the bulkhead drain passage while you're looking down at this the precise spot if it will be leaking inside .. if the test appears to be positive then remove the wing and re-seal the panel gap ..
Edited by DamirGTI
Henry 1.9GTi
looks like its wing off for me too. Cheers, for the pics Damir
gti-si
BOLLOCKS
Look's like it should be wing off for me too...It can wait
