hcmini1989
Kent Cams Pt1602
hcmini1989
hi just found some kent cams and vernier pulleys on ebay just wondered if anybody was using or have tried one the part number is pt1602 says its a supersports r cam.anybody know what they would be like for fast road and trackday use.allso looked it up on kents website and it says i would need some hydrualic cam followers but couldnt i just use the standard ones or can anyone reccomend some cams on a tight budget aswell thanks for any help
hcmini1989
right ive done a little search and found out what i need to know its either these or a petert cam .
1602's are fairly mild iirc, and use std followers.
  Quote
Application Sports ' R '
Power Band 2000-6500
Cam Lift(mm) 10.94
Valve Lift(mm )10.94
Duration 264 Deg
Timing 22/62 62/22
Full Lift I 110 Deg E 110 Deg
VC (mm) 0.00
LTDC I 1.65mm E1.40mm
Required Parts CF55
seems quite mild, then the next cams up in the range look quite different, though they don't state where the duration is measured, where many measure at 0.1 and 1.0mm which gives a slightly better indication of what they're like.
They look to be fairly close to PeterT's stage 1 cam.
