Saveit
Does The 1.3 Euro Rallye Weber Manifold Fit Other?
Saveit
Hi,
Did a search but couldnt seem to come up with anything.
So my question is, as i have a 1.3 euro rallye weber manifold which i intend to sell, if this manifold fits any other TU engine? If so, which?
Stefan
burr_2000
No the 205 euro rallye had a unique stud pattern, so wont fit another TU engine.
Saveit
So the stud pattern is different, but how about the ports? Could it be that you could drill some new holes in the manifold to accept the other stud pattern, or is it too different.
drmo
No you cant. The only problem is a stud between the carbs. I gues you could weld some material to the head and drill a hole for the stud.
Then you could fit it to any big valve head (rallye, xsi,...), but also have to veld/block the holes for injectors. The intake ports are the same as these heads. :blush:
