jwa
309 Gti 16v Exhaustmanifold On 205 1,9 16v !
jwa
Hey ...
I have a 205 1,9 GTI kat., in wich i have mounted an 405 1,9 MI16 kat. engine in (i need the kat.).
My problem is the exhaust. I have 2 options:
1. 309 GTI16V exhaustmanifold, standard 205 1,9 GTI kat., standard 205 1,9 GTI middle and rear sektion.
2. Pugspares manifold, some homemade kat. solution, standard 205 1,9 GTI middle and rear sektion.
I prefer solution nr. 1 ... if it fits. Does it ? ....
I would like to use as many standard parts as possible. So when something goes wrong, its a straight bolt on, for the new parts.
The engine is, for the moment, standard. No tuning.
Any sites, pictures (can be send to: wassard@stofanet.dk) are velcome .... ;)
Let me know what you'l do ...
Either way both will need modification to the std downpipe/centre section to make fit.
jwa
ok ...
What is the problem with the 309 setup ?
Edited by jwa
Pugspares Manifold!! You can buy mine which comes from the same supplier for £100.00 less
