Guest Alex_cmyk
Which Rallye Steels Are Widest?
johnnyboy666
s2 106 are 6j i think, 205 are something around 5j i think
Guest Alex_cmyk
Would 106 fit under standard arches?
johnnyboy666
i should think so, people have done it, they just might be slightly borderline at mot time as theyre supposed to be inside the arches. having said that my wheels stick out about 1.5 inches either side and i havent been pulled over or anything for it, although i havent had an mot since its been like it. you can get rallye arches relatively cheaply on ebay ;)
Guest Alex_cmyk
Ya I was planning to put GTi arches on. Just been offered a set of S1 Rallye steels (106) are these the same as 205?
jonnygoodhand
No. 205 Rallye Steels are 13".
Guest Alex_cmyk
oh really... i'll go for the 106 steels then
DaveW
6'' fit fine with 185/55
Edited by DaveW
johnnyboy666
phase1 106 rallye steels are 13s arent they?
Fox
No, but they are only 5 1/2 inch wide.
Guest Alex_cmyk
not THAT much different to s2 then
Guest Alex_cmyk
Which size for tyres are recommended for 14" wheels?
And also which would fit best s1 or s2 106 wheels? I'm reckoning s1 would be easiest as they're narrower...
I'd go for S2 wheels and use 185 60 14 on a 205 :wub:
Thats the size I used on mine, S2 6 x 14 106 Rallye steelies.
They fitted fine on an STDT which has the GTI arches / shell even when I lowered it about 30mm.
Jrod
On a base model shell I'd stick with 185/55
Guest Alex_cmyk
Mines's base model but I'll be putting GTi arches on it soon. It's lowered 40mm at the front, I thinka bout 20mm the rear but will be evening it out
jonnygoodhand
I ran S1s with 185/60s on a base model shell, lowered around 30mm, with no issues at all.
