Vts Loom
On my vts loom there is a plug which plugs into a sensor (I presume that's what it is) which is located on the high pressure pipe between pump and rack. It plugs in on the high pressure pipe as it goes down in front of the engine (behind rad).
A) Does anyone know what this plug / sensor is for? Does the ecu take a readin from it or something?
and
:( Does it need to be plugged in on my 205 conversion?
Thanks,
Pete
M@tt
it's not used in the conversion, just plug it into the sensor so it isn't dangling around and just ignore it
Thanks - do you know what it is used for originally though? Just out of interest really.
jplautomotive
yeah it ups the revs at idle when steering is turned , and pressure goes up
jon
