dino20vt
Ecu Mounting Plate Removal
dino20vt
I took the 8v engine out of my 205 complete with an intact loom. I was in a rush to get the big ecu plug out i damaged the mounting plate to enable this to come out. Im now regretting this now as it doesnt look easy to change.
not out totally, but you do need to loosen and pull it away from the bulkhead as the offside mounting stud does go through the ecu bracket.
dino20vt
Might give it a miss then!
