Guest richt
Side Badges.....
Guest richt
Most of the clips are broken - has anyone stuck theres back on, if so what with?
Rich
Guest phil19gti
A hot glue gun works very well.
Guest hd_andy
Has anybody found a way to stop the bastards stealing them I was thinking of something along the lines of electrocution!
Rob_the_Sparky
Worth asking I guess
Guest Hungrytang
Mine were nicked off my 1.6 and AUTOFIVE were the cheapest place to get replacements.
205man
yes pug still sell them although not cheap though. autofive or ask on here
i stuck mine on after the pins broke i used an epoxy resin that supposed to withstand 1500psi of pressure, and theyve not moved, i got it from halfords about a fiver
alan
Ahl
I pushed the broken pins through from the inside (through empty rear speaker holes) and carefully araldited them back on. I also put some silicone sealer around the pins on refitting.
I sanded and smoothed my rear badges to add a bit of 'misssteeek' and also to deter theives from nicking them.
They go well with the graphite grey car and make it look a bit less 80's imo.
Steve.C
What ones are you missing Rich as i have my old ones in the garage
Guest richt
Both the 1.9 and Gti on the passenger side have broken clips and have fell off.
What ones have you got going spare?
Guest ADRIAN
Black silicone.
Load the back of the badges with it and it'll be stuck
forever.
Guest richt
I brought some clear silicone wasnt sure if it would be up to the job.
Guest Rafe
Mine fell off hundreds of times with all so called tried and tested techniques. So I got my Black & Decker out and drilled a small hole through (from the reverse side to ensure accuracy) the plastic covers. Then insert what's left of the plastic into the hole (it's probably there already) and use a suitable sized (modern self-drilling type)screw in through the cover to the hole, and into the remaining plastic (there should be a little bit of a hole in the plastic if it fell off right). You can sharpen it up with a dowel (?) drill so that the screw head is flush and cover with a touch of filler (Polyfilla?) for a perfect job. Never shifts again.
Rafe.
Guest SuperFLY
silicone sealant sorted mine after i colour coded them nicely ;)
Steve.C
I will look in my garage and post later,im pretty sure i have both passenger side badges,im sure the clips are broken but gripfill works wonders
