TRYNKEEPUP
Window Tint
TRYNKEEPUP
Just purchased a daily runner 1.6 gti so i keep 1.9 in garage, trouble is new car has blacked out windows, thought it would be a ten min job removing it, just picked edges of tint and it ripped of in sheets! lovley i thought, but there is now all the old adhesive all over windows, have i got to rub like hell with paint thinners or petrol or is there an easier way !
SurGie
Using a heat gun.
hexhamstu
white spirit as you said should do the job.
xxvickyxx
heat gun FTW
ALEX
I used the kettle to remove the film and then turps on the glass to remove the sticky gunk using the rough side of a sponge.
Edited by ALEX
Richie
White spirits, or a use a sharp T blade+warm water with plenty of elbow grease. There are adhesive removers on the market, but from experience they are a bit useless.
Park your car in the sun fior a few hours.
The tints came off my 306 just by lifting the corner & pulling, I didn't need any heat to get it all off.
Graham.
dk73
Graham.
Good idea graham, ive done alot of car valeting and had this before.
I used autosmarts preptone and it came away easy, you can also use any based solvent ie panel wipe or thinners. :D
