billybluesky
Zx Rear Arms
billybluesky
hi after reading that zx rear arms are a replacement for 205 items what are the advantages and which zx arms are the most desirable thanks
Cameron
Have a quick search, there's lots of threads on this. :ph34r:
billybluesky
Have a quick search, there's lots of threads on this. ;)
Tried tried tried used the help concluded i havent a clue how to use the search (seems a common topic) maybe there`s a thread on it (whats a thread? computer illiterate welder) i guess i could flog through all the pages then again ignorance IS bliss
James_R
In short better turn in and slightly more camber on the back.
SurGie
Much better for the track than the road, not quite as nice on road use, iv been told.
The 306,xasra arms have toe in, which is a bit better for road use but less sharp turn in corner's.
Do a search, there is loads on ZX arms, type ZX*arms then you'll find some, i recently
posted pic's of my set with ABS bracket
Don't believe all your told, I have them on my car & its fine on the road.
TBH I don't believe the majority of drivers can really tell the difference between different arms anyway.
I'm sure Anthony said he couldn't really notice a change with them & neither can I.
Graham.
James_R
Did you find more even tyre wear on the back graham??
I found I was still getting too much on the outer shoulder, so I'm working to reduce roll more, and add camber to the rear aswell, still trying to get even wear at the back.
I haven't noticed it yet but I've only done about 4k since fitting the ZX arms & some with track wheels fitted so not all on one set of tyres but my beam also has 20mm TB's & a 24mm arb.
I have noticed the rear tyres are working harder on track though because they are getting warmer than I remember on the previous 205 arms.
Graham.
