spikey_richie
Gentry Driveshaft
spikey_richie
Just had a look under the car and noticed my O/S driveshaft boot on the back of the hub is split. Do I just need a new boot, or a whole driveshaft?
If I need a driveshaft, is there an auto version or can I use the regular 1.9 GTi one?
If it's a CV boot, do I need inner or outer? Is inner gearbox end, or hub end?
Ryan
If it's just a split boot and the driveshaft isn't noisy and the joint doesn't feel rough, then replacing the boot is probably enough. Inner is the gearbox end, outer is the hub end.
If it does need a new driveshaft than I think the Gentry uses 1.6 driveshafts.
spikey_richie
Nice one, thanks Ryan. BTW which part of Nuneaton are you in? We're on Eliot Court down by bermuda village
Ryan
I live in the far end of Stockingford.
I've seen a gold Gentry about. There can't be many of them in town, so it's probably yours. :lol:
spikey_richie
Yeah only one in town; reg ends UKR. There's one in Cov I've seen near B&Q on 2 mornings but not been close enough to check it out.
Edited by spikey_richie
