Peetypug
Gti6 Wiring
Peetypug
i'm trying to sort out this new loom for my car (i melted my old one on the exhaust)
not sure if its a gti6 or xsara vts one
i copied all the the wire numbers/colours from my old loom and where they were connected on the 8v loom
all but 2 of the 8v wires are connected
they are
red 2a (9 pin)
grey 12b (6 pin)
i've cut none of the smaller plug wires
but i have 4 that i have cut and 6 that are still connected to the 19 pin plug
cut wires
cream 480 - k light
yellow 465 - vss
grey 123 - lambda
red 426 - rev counter
un cut
yellow 414
green 140
grey 001
earth m444
cream 141
green 415
so which of the above wires connect to the 2 8v wires
red 2a needs a switched live and the lambda wire
grey 12b is what i'm going to connect to the tacho loom i got off spikey
Edited by sorrentopete
Spiky
didnt i make you a loom? or is that the one thats melted?
140 - diagnostic socket
141 - diagnostic socket
414 - oil level indicator
415 - oil level indicator
have you answered you own question here now?
as the post isnt too clear...lol
nick9one1
not sure if these will make it any easier to work out but here are both the pre and post 97 gti6 diagrams, also a xanta vsx.
post 97
pre 97
vsx
Edited by nick9one1
Peetypug
the one i had off you i melted :D
comparing it to the loom i had off you there are a few differences
red 2a is connected to grey 123 - lambda plus one other, which is white 259
on this new loom there is no white 259
Spiky
wire 259, dont ring any bells,
the only wired i normall connect to the red switched live wire are lambda and the ignition relay (pin 14)
