Paul_13 212 1 Cars Posted May 3, 2009 Hi does any one have the part numbers to rebuild a steering rack. It's a non power steering 205 rack. Its got sh*t loads of play and im replacing the rack and pinion with quaife items. Could do with another body for the steering gear aswell, does any one has one? Thanks Paul Share this post Link to post Share on other sites
Paul_13 212 1 Cars Posted May 4, 2009 Does any one have the part number for the bearing and seal for the pinion gear. Any other bushes etc would be helpful Share this post Link to post Share on other sites
Alan_M 66 1 Cars Posted May 6, 2009 Dunno about the seal, but I should be able to get you a new bearing for free. Can you get the bearing number off the old one, or failing that get the outside diameter of the pinion and inside diameter of the body the bearing fits into? Bearing 6206 rings a bell for some reason....... Share this post Link to post Share on other sites
welshpug 1,675 Posted May 6, 2009 you do bearings at work then Alan?... Share this post Link to post Share on other sites
Alan_M 66 1 Cars Posted May 6, 2009 you do bearings at work then Alan?... No, just happen to have a fair few of the pinion bearings, 6206Z I think. Share this post Link to post Share on other sites
Paul_13 212 1 Cars Posted May 8, 2009 Thats v. helpful Alan, I'm back from Leeds so i'll get round my mates and double check. The bearing's pretty mashed so hopefully i can spot a number Share this post Link to post Share on other sites
Alan_M 66 1 Cars Posted May 8, 2009 Is is a spline or square pinion? Its a 6002z for a spline, if its a square then you may have trouble sourcing a new bearing as swordfish found here. Share this post Link to post Share on other sites
Paul_13 212 1 Cars Posted May 8, 2009 It's a splined jobby, how much would you want for this? Cheers Paul Share this post Link to post Share on other sites
Alan_M 66 1 Cars Posted May 8, 2009 It's a splined jobby, how much would you want for this? Cheers Paul Nothing Share this post Link to post Share on other sites
