dino20vt
What Lubes For A 1.9 Mi16
dino20vt
Sorry, im sure its been asked a million times before but my phone doesnt like the search facility on here!
What transmission oil, power steering fluid and engine oil does a 88 mi16 use and how much?
bensonmi
not sure which engine oil, i want to know myself!
but i can tell you you need 2 l gear oil,just fill it till it starts dripping out.
i used halfords transmition oil but cant tell you if its any good or not
KRISKARRERA
Engine oil is 10w40.
Gearbox oil is 75w.
Not sure what the exact spec of the power steering fluid is, is it wrong to be using automatic transmission fluid then? :ph34r:
dino20vt
Ok then,
Halfords and the 205 Haynes says 87 onwards BE1 and BE3 gearboxs take 2 litres of 75w/80,
Various local motor factors say 75w/90?
Halfords says 15w/40 for the engine oil,
Haynes 10w/40.
Everywhere agree on Dexron type ll ATF (automatic transmission fluid) for the PAS
So who is correct?
jplautomotive
75w80
10w40
atf II
1.8l of 75w80 for the box (level plug on the end casing anyway)
5.3l of 10w40 depending on preference i guess, for the engine. Also depends if you're running an oil cooler etc etc too.
Edited by Baz
Anything on the engine, Most would have any old stuff in them by now, But a good one I;ve found is the Fuch's XTR 10/40, I had a engine run about 10 miles with a broken oil pump chain and it survied it and ran when repaired
dino20vt
Mineral, semi or full? My preference would be semi synthetic for cost reasons, is this ok to use and still stick to 10w40?
That's fine - semi-synth 10W40 is what I've always used on 8v's and Mi's :lol:
