mikespug
Peugeot 205 / 309 Gti Group N Gear Linkage
miamichris
Better off speaking to Miles (Pug Racing) on here and spending your money on his gear rods, they're much better by the sounds of it. I'll be putting them on my own car :)
I'd buy these ones ^_^Pugracing gear rod shop link
the constella quickshift is a very poor one, they come loose all the time, I know as I have one on my car :)
IIRC Miles can supply a bolt on ball joint so you can make your own quickshift for a few quid and a single drilled hole in the quadrant lever.
Flix
Another vote for Miles. I'm using his rods, great quality.
I know I'm biased but we all are at the end of the day, So some Basic fact's of using the different types and by all means add any points
1. All my Rods are Steel and Plated (as in the listings) so are much stronger than any Alloy rods
2. My ball joints use 2 clips, One to secure around the ball and the other is a safty clip to stop it falling off, Having used the Constella ones they only use the external clip so they do rattle slightly.
3. The Quadrant bush I supply really removes the need for a Q/S as with the rods and a non wobbly Quadrant arm means little to no play.
4. All Single piece construction, No welding or Studding used for ultimate strength
5. 12 Months warranty and all parts can be supplied if required
SurGie
Interested in a set once my project get's ready for them.. :D
vickiw106
i use this kit on my rally car
supurb kit its seems to be well made i fits really well
also very easy to adjust if needs be.
cheaper than rose jointed kits and also if you have to replace anything as far as gearbox, swivel arm etc you dont have to modify it in any way.
hope this helps
philfingers
I made my own rosejointed kit for about £18 with some M8 threaded bar I had kicking about. BUT this nisn't a fit and forget option like the others. rod ends need servicing periodically. if it's a track or rally car that's fine but if not it's more hassell than it's worth
MerlinGTI
I run the Constella ones and they are brilliant. Been on there about a year now, still look like new, no issues at all with them. Fit and forget :lol: (well maybe clean and regrease them once in a blue moon)
Mikey S
I run the Constella ones and they are brilliant. Been on there about a year now, still look like new, no issues at all with them. Fit and forget :D (well maybe clean and regrease them once in a blue moon)
same here, very pleased with them. would recomend.
mike
i now have my new rods and fitted thanks Miles
but now i after a quick shift has anyone tried this http://shop.ebay.co.uk/items/__quickshift_...286Q2ec0Q2em282
Link FAIL :lol: which one were you referring to?
are the quadrant (L shaped linkage) and gearstick bushes in good condition?
you can make a quickshift in about 10 minutes with a drill and a new ball fitted closer to the pivot on the linkage quadrant.
mikespug
yes mate all ok was on about the quadrant 1
how do i do this then ? could`d see how to take it off when i was under the car :lol: and how much closer do i put it ??
mike
EdCherry
Miles sells the ball joints and provideds instructions for something like a quid or two! Move it about 15-20mm and you get a nice change.
mikespug
sweet i have emailed him asking but did`t hear anything back
how short will it make it ???
mike
EdCherry
Cant tell you on a standard stick as I modifed the entire system all at once. You can make it as short as you want, but you get to a point where it becomes hard to find gears. Id say moving the ball joint 30mm would be your maximum, and would create a nice shorter shift.
philfingers
i'd say 15/20mm is ok, as Ed say anymore and it's more minus than positive benefit
