Rich_p
Harness Length
Rich_p
Does anyone have a rough idea of the length of the rear straps on harnesses needed to fit them to the existing rear belt mounting points?
(not idealI know but it's until I can afford to have some harness bars fitted to the cage)
As long as you order standard harnesses and not the caterham/westfield types then you'll have plenty of length in my experience. However another solution is to drill through the lip at the front of the boot floor which allows the belts to sit at the correct 45 deg angle, and straight back from the seats. If you use some plate to reinforce the area this is plenty good enough.
