carlh.1 8 Posted April 7, 2009 does any1 know how to remove the ignition barrel after ive taken out the small screw from the top Share this post Link to post Share on other sites
Anthony 1,002 Posted April 7, 2009 There's a couple of protruding lugs on the bottom of the barrel that can be depressed with a small screwdriver when the key is turned part-way, and then the barrel pulls out, taking time to avoid snagging the wiring (particularly if it's been butchered by an alarm installer) Share this post Link to post Share on other sites
Ryan 99 Posted April 7, 2009 You have to put the key in and turn it to a position half-way between the first and second click (there might be a line on the barrel to show where), then you should be able to push the locking pin in and slide the barrel out. Share this post Link to post Share on other sites
carlh.1 8 Posted April 7, 2009 ah, those 2 under the bottom! thanks alot Share this post Link to post Share on other sites
