Mr_save
Mi16/s16 Engine Loom
Mr_save
Hi there! here`s the question...
Im running an 1.9 Mi 16 (alloy) from a 405, i`ve modified the original 205 loom to fit the 405 mi16, so is without dizzy adaptator!
now, is it straight on if I want to fit an S16?
last thing, if i want to put a GTI6..?
Basically i want to do that because I cant find another Mi16 in good conditions...
You can run an S16 on 1.9 Mi managment, loom etc, but using all the 1.9 Mi bits, inlet manifold with TB, throttle pos. sensor, ICV etc.
Mr_save
TNZ Baz!
:D and for the distributor...?
TNZ Baz!
exactly what I was going to query!
can you not use the S16 loom?
Run a 1.9 Inlet cam and the 1.9 'dizzy'
Mr_save
smart.... :D
ahh and the thermostat housing too I take it?
yep!
Mr_save
yep!
Instead is it possible for the GTI-6?
if you go for a gti6 you really are far better off going to the effort of fitting the loom and ecu correctly :D
Mr_save
Even using the normal 5sp gearbox?
Where can I found another Mi16 in good working order?
gearbox has no bearing at all on the engine wiring :unsure:
Mr_save
gearbox has no bearing at all on the engine wiring :wacko:
:unsure: I was talking about the difficulties on the gearbox... not the wiring :wacko:
No you cannot do the same on the 6 engine, I did the conversion about 10 years ago now and have doen a few since and all run better than the S16 loom as well
