Mr Bob
Unkown Connector
Mr Bob
hi
just fitted my S16 engine but there is one connector i cant find where it goes can anyone please help?
thanks alot
bob
M@tt
diagnostics socket :D
Mr Bob
thanks for that :D
the engine wont start and i was hoping that would fix it but obviously not
M@tt, are you sure its the diagnostics socket?
I've only ever seen them in green & not usually in the middle of the loom.
How many wires go to it & can you see any numbers on them?
M@tt
I'm positive i've got one on mine there (granted its a GTI6 but almost the same) and its got a little blanking plug thing plugged into it.
The only other things around there could be the oil pressure switch on the block above/behind the starter.
Knock sensor has a green plug but doesn't look like that either
Spiky
oil pressure on the gti6 are grey
there is a spare black on the gti6 which is located by the TB
maybe its the same on the s16?
