205Rallee
Washer Motor
205Rallee
Help!
The windscreen washer pump on my 205 Euro Rallye doesn't work. I've taken the connectors off the pump, cleaned them up and reconnected them. Haynes says it's on the same fuse as the break lights and they are working. The pump worked last year and it passed the mot last month..
Any ideas?
Ethos
They are about £12 in halfords, sounds like you need a new one :D
Can you hear it whirring when you pull the stalk back? Saying that when I bought our 205 it wouldn't work cause the stalk was a bit "off". Took it apart and put it back on and it worked fine!
NeilGTi85
Try running a cable from the + on the battery stright to the pump....if it does not work then you know its the pump.
