Paul_13
[trackday_prep] Paul's Gti6
Paul_13
I'm taking my time doing it this time and have got a mate's garage to do the work in.
I'm pretty confident ive had all the problems with this engine so far apart; from a snapped belt and melted pistons so should get it right first time :) Or have the melted pistons to look forward to :lol:
Obviously do a good couple of thousand miles before considering a charger.
Paul_13
Was getting somewhere:
All torque'd up
Windage tray and oilpump
New chain and sprocket
Dipstick pipe
Crank seals
End plate and sprocket cover fitted
Sump on
Pipes and sensors on
Went to fit the water pump and found this:
AAAAAAAAAAAAAAAAAAAAARRRRRRRRRRRRRRRRRRRRRRRRRRRGGGGGGGGGGGGGGGGGGGGGGGGGGHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
:angry: :angry: :angry: :angry: :angry:
Really really really pissed off, I think this could of been damaged a while back in my shed, or Ryan's garage as it's changed hands a few times. Hard to pin point as it's been lying about for years. My step dad could of thrown something in the shed ages ago in a tantrum (because of my pug bits taking over :lol:) and it's gone unnoticed til now.
Again another mistake i've learnt my lesson from, always double and triple check condition of parts. I've got another block in the pipeline I believe which i'll be picking up Friday. Fingers crossed.
Edited by Paul_13
Oh that's a sh**ter - I didn't realise that you'd built the whole bottom end up before you discovered that! :o
Paul_13
Yeap!
It's too close to the water jacket to weld a repair section in and plus I wouldn't want to anyway, as it would be playing on my mind too much. <_<
My mate dropped some of the main end shells when we were taking them out, so I need to go buy a new set. My fist hurts from where it made contact with the wall
SurGie
Thats right Paul, keep thinking positive about it all even if your fist really hurts a bit.
At least you can corner better than a 205 V6 mate, non of that extra long front end weight, speed is all fine but on our British roads/traffic pile ups its all about the corners, it is for me anyways :lol:
Good luck Paul, it will be worth it in the end.
Paul_13
Shiny bits :)
Stripped it all down last night, everything's back out. But my mate managed to drop the main end bearings.. d'oh! Better go buy some new ones.
Tesstuff
Surgie, find one corner you can take quicker in your 205 than I can in mine........shall we film you trying lmao :D
Paul, sorry to see even more bad luck coming your way mate, stick in there fella. :)
Paul_13
Sorting out the bay rust, wire brush wheel and kurust ftw! Luckily no holes just surface rust, front panels in one piece! :)
This area looked quite bad but it's come up well. Dug out the sealant in the corner to make sure it was ok and it was :)
Gave the discs I got off Anthony a clean as they were sat outside in the rain for too long. Came up well.
Rusty battery tray unrusted :)
And this thing living in the shed getting high off the paint fumes. Lovely colours
That is all. Picking up new block tomorrow night and take 1, 2, 3, 4, 5, 6, 7!
damien
Shiny bits :)
did you find the inside of the inlet covered in crap? if so how did you clean the inside
Paul_13
It was mate, to be honest I've left it for the meanwhile. Was thinking of getting some thinners/petrol letting it soak, then blasting it with the jet washer.
But will probably mean painting it again :lol:
Just stick it in the Dishwasher, Just don;t let the Mrs's see
DRTDVL
Whats the lip on your car off?
Paul_13
:lol: I'll put it before I get the block
Paul_13
Off a Renault laguna I think mate. It's not the usual one
damien
dont have one (dishwasher i mean)
Paul_13
Just picked new block up :)
Will start building it tomorrow :)
Phew post count was 1666 before this :o
SurGie
I would not like to use the dishes after the dishwasher has washed the inlet tbh, unless you get one of those dish washer cleaners.
Beans on toast with extra carbon :lol:
Paul_13
Found some rust after a bit of prodding :( Cut it out, just got to bend a bit of metal and weld it in.
Painted the servo black, much better :)
Finished the other inner wing
Crank in (again)
Sump on (again)
I have 0.10 endfloat one way and 0.15 the other, that enough? Bit late to be asking
Edited by Paul_13
How can you have different end floats each way? End float is how much clearance there is. Lever the crank hard over one way, then measure the clearance.
Paul_13
Thats what i've done and got different measurements on either side :P
Might be the engine lube stopping it from shifting over fully.
Either you are not measuring it properly, or there is an issue with the thrust face on the crank, tapered etc
Paul_13
What measurement should I be going for?
Paul_13
This is on the wall at work, tempted to pocket it :lol:
Repair plate for inner wing
New shocks
Head on and torqued
Brackets, pipes and sensors on
Shiny bits
Belt next, ive tapped the threads to clean them up and the idler is already torqued! The correct grade bolt used and awaiting another tensioner bolt as mine was rouded slightly fingers crossed it will turn up tomorow
Edited by Paul_13
Paul_13
Stud and nut?
Or bolt?
Little bushe thing
Exhaust manifold on, had to tap a few holes as the threads were a little buggered
Shiny alternator
Need some jubilees
Squawk!
Just waiting on the lightened bottom pulley :rolleyes: then I can do the cambelt
Edited by Paul_13
Paul_13
Timing belt done
Mocked up the tensioner setup- Still awaiting my lightened bottom pulley :angry:
Throttle body on, going to blank off the oil recirculation pipe on the body. Pics soon
