eck_johnston
Battery Charging...
eck_johnston
Hi,
A wee but occasionaly very irritating problem...
Basically, unless i take revs past about 3500, the battery is not getting charged. Tell tale signs include slightly dim lights, sluggish wipers etc.
Obviously, this is rarely a problem, but sometimes (like yesterday) when for example i have very little petrol in the car, i bumble along changing gear at low revs, forgetting that the battery is getting drained. I stop, put fuel in, and then of course discover that the car won't start. Very chuffin annoying.
Anyone else experience this? Is it a shonky voltage regulator/alternator?
One of my friends has the same problem on an old series 3 land rover....
Cheers,
Eck
Ethos
It's the "excite wire" on the alternator. There is the main thicker cable that goes to the starter from the alternator and a smaller spade connector that goes to the brown multiplug (excite wire).
I'd take this off and clean it up and make sure the connection is ok...
Edited by Ethos
Yes, as above, also check the connection through the brown multiplug of doom is OK.
I'll bet that your battery light isn't working either?
eck_johnston
Cheers for the responses - I'll have a gander this week at some point and take advantage of the nice extra hour of daylight.
