weejimmy
Is There A Alternative To Eibach Springs?
weejimmy
want to drop my g/fs 205 30-40 mm ive had avo spax all the usual springs before but when you go over a bump or jack the car up the spring becomes lose as its too short.
i put springs on my own 205 that had to be compressed a tiny bt to get on but not using spring clamps. these are much less clashy over bumps but i dont know where they came from.
i presume eibach will be like this ( need to be compresed when fitting) so will be less clashy too?
is there any cheaper springs that are good and not clashy? or do i just need to fork out for eibachs?
thanks
Batfink
To get a good ride you need a decent quality spring material.
You can't go too wrong with the eibach's. They really are worth the money.
Kev
As with everything you pay for what you get and I;ve yet to try a spring better
weejimmy
got a pair on order thanks
Guest Tony_180
you wont regret your purchase eibach springs truly are the mutt's nut's.
Henry Yorke
Agree with the above :)
