andychalmers
Close Ratio Gearbox
tomcolinjones
hi, i have a mi16, 1.9 and a 1.6 box. i am mid point fitting the mi16 engine to my 205 and will be using it for road rallies 'night events' is it best to use the mi16 box, or the 1.9 with the mi16 cwp? i will be fitting a tranx lsd. which ramp angles would i need?
1.9 with the Mi16 final drive would be good, you don't need top speed for the lanes :lol:
Can;t answer for the ramp angles, depends how fierce you want it and the surfaces really, Miles can advise I would imagine.
tomcolinjones
is it a big job to swap over the final drives? what rato is the mi16 fd? comapered to the 1.9 gti one?
thanks
also. miles if you are reading this, what ramp angles would i need? i plan on using pas, and it is mostly lanes, with a few whites ' mud/gravel sections'
Mi16 FDR is 4.4 compared to the 1.6/1.9's basically 4.0.
close
Mi16 - 4.43
1.6 GTi - 4.06
1.9 GTi - 3.62
Mi16 cwp in a 1.9L box is definitely the cheapest and best option for your application.
alync406
You have to completly strip the gearbox to fit the pinion which is part of the main shaft.You have to take off the back cover to fit the crownwheel/diff. You have to swap all the gears onto the new shaft. 1.9 gears and the Mi16 final drive is a good combination. The 1.9 and 1.6 gear ratios are pretty similar but 1st is very short in the 1.6.
The Mi16 final drive is 4.4:1, 1.6 GTi is 4.0:1 & 1.9 GTi is 3.68:1.
haro09
hi, on my 205, i've a 19/79 cwp of citroen xantia (4.15 ratio)
but we also find little jumpy or on xantia:
jumpy 1.9D (DW8 engine) 15/74 (4.93) or 15/76 (5.06) BE3 and BE4 gearbox
jumpy 1.9D (xud engine) 17/81 (4.76) BE3 gearbox
jumpy 2.0i (ew10j4 engine) 14/62 (4.42) or 17/75 (4.41) BE4r gearbox
xantia 1.6i, 1.8i, 2.0i
(19X72) (16X61)
(19X75) (16X63)
(19X77) (16X65)
(19X79) (16X67)
xantia 1.9 td (xud9te engine) 15/64 (4.26) 16/65 (4.06) 19/77 (4.05) be3
xantia 2.0i 16v (xu10j4) 15/64 be3
xantia 2.0i 16v (xu10j4r) 19/79 be3
I've also thinking to the mi conversion for my 205 (i've two 14/62 cwp in my garage)
but my setup is ideal for my use :):)
