swordfish210
Half Dash
swordfish210
Hi, does anyone have any pictures of a cut down dash i.e. most of the centre console removed and just the top part remaining. I'm thinking of doing it to mine but i need some insparation :wub: Thanks. Mark
Jrod
ALEX
Base modles that don't have a centre console have a plastic cover to cover all that wiring and the heater matrix.
swordfish210
Thanks, thats the sort of thing i was after. Any more?
Just to roll it into the same topic, what about just the driver's half too? :)
swordfish210
Well i'm keeping the heater in it so i'd like to keep the standard switches and knobs really.
AdamP
When I change the engine i'll sort out the wiring, redo the fuse box and remove the passenger side of the dash.
swordfish210
Thanks adam, i take it you took the dash out to do that. How do you secure the fusebox in place now?
AdamP
Left the main part of the dash in, just took the bottom half off, cut it and screwed the top back on! I also cut the little bit that holds the fusebox off and screwed it back on, and cable tied the rear ball bit up!
Jrod
swordfish210
Thanks guys, i'll whip the dash out sometime soon and start cutting :)
