buster205
Sunroof Removal
buster205
hi all
is it possible to remove sunroof and weld up the hole ? it's not an original s/roof, it's a solar slide ? i think i'm right in saying the hole is quite a bit smaller than the hole with oe sunroof. Can it be mig welded up without warping the roof ?
cheers
Ste
EdCherry
The roof is a bit thin, might be hard to do, havn't welded in all honesty so couldn't tell you.
buster205
my bro-in-law is a welder so i'd get him to do it, but i was hoping someone had done it before, rather than finding out the hard way it can't be done !
cheers
Ste
swordfish210
The roof will warp like f*** if you weld it, the steels too thin. Get an aluminum plate cut and bond it in place.
Cameron
Yeah the biggest problem with welding it is that you'll never be able to do it without warping the roof.
buster205
would i be better cutting it oversized and bond it from the inside, then have it filled smooth and painted ? the only concern i've got is if the filler cracks if it flexes at all ........?
cheers
Ste
Thy really don't look that bad on the outside IMO.
Cameron
You'd need a LOT of filler too, and it would be very hard to get it to look straight.
buster205
yeah just been out on my mtb and me mate said the same about the filler, but i would have thought you would only need enough filler to level it with roof skin which as stated in previous posts is very thin ? then again i'm better with the mechanical bits havn't got much of a clue when it comes to bodywork matters !
cheers
Ste
toddydal
with any welding its the heat that distorts things so the less heat the better,if the part your going to weld in is the exact shape for the hole it will be easier,when you have an exact fit you then want to tack the roof in all 4 corners and then the middle parts making sure you have the plate flush all the time to the roof,then continue to tack all the way round the roof till you have covered all the way round with tacks then grind all the tacks off andthen re- tack the bits that you have missed then grind off again and then fill,doing it this way will not distort it as much as if you try to do long runs of weld because that will cause to much heat and distort the roof to f*** then you will need s*itloads of filler
buster205
i've found a n reg base model 205 in local scrappy, might see if the bloke will let me cut a chunk out of the roof to make a patch for mine, i'm now thinking of going down the bonding from the inside route, at least if i use a donor patch from a 205 roof the contours should be the same!
cheers for the advice
Ste
BackStreetRacecars
if you are especially good with gaswelding slowly do a nice gasweld along the seam and get someone to follow with a soaking wet rag. :D I have done this before with bodywork and it has worked well. ;) But personally I'd bond it then have a stepped overlap and run rivets all the way round it'd look kinda lika a joint on a plane....awesome.... :wub:
Another group buy on the sunroof plates anyone??
buster205
cheers for the info mate ! i think i'm right in presuming the main reason people want to do away with their sunroof is for track use ? (sorry if i'm wrong), the only reason i want rid of mine is because it's an aftermarket roof with dodgy/ugly rails on top and it vibrates like mad at certain revs ! really doin' my head in, so i want the finish to look pretty neat.
cheers
Ste
BackStreetRacecars
yeah i'd say motorsport too probably... maybe even just getting sick of poorly fitted leaky sunroofs!!!
wardy18
I need to do mine on the hillclimb pug, its got an ugly oversized section bonded and riveted on the outside at the moment and I hate it, looks tacky as s*it!
Best way I and my bro who has a bodyshop can think to do it is like what has been said, get a oversized plate then trace the exact size of your sunroof hole and then step the plate so when u bond it to the inside its sits completely flush on the outside, small amount of filler to finish and happy days
buster205
cheers mate nice one
Ste
Cameron
Its not the heat that does it, its the welds shrinking as they cool that pulls everything all over the place.
Get yourself a joggler. :)
buster205
joggler ?
andykandy205
this might upset a few people with what has been done to the car but this started life with a sunroof then welded over and filler..
Once again im sorry what i did to the car i was very young....
Not the best pics but you can see first pic with sunroof second without.....
buster205
alright mate !
Did you weld up sunroof hole yourself ? how did you weld it ie- gas ,mig, tig?did the roof warp at all ?
cheers
Ste
EdCherry
to be honest, that car isnt bad mate! looks nice red, would change a few things myself but otherwise nice.
Cameron
A joggler is a handy tool that makes a lip in the edge of a panel so you can butt another one up to it and have a flush surface.
If you're going to get this done (it seems like you're pretty keen on it) then I'd take it to a bodyshop.
marksorrento205
If you are going to go to all this trouble why not just replace the roof skin with a non sunny one for just over £100 from pug? Sorry if this has been said already, I may have missed it. It might be a bit more work but at least you know you wont end up with a warped roof.
buster205
i have been considering that option but when i had my front screen seal replaced a few weeks ago i noticed the roof seem is under the seal and if they don't get it spot on i could be plagued with leaks......(and touch wood i think i've just got the car watertight) !
cheers
Ste
Personally I would change the skin, making a good job of plating the hole is probably more work than changing the skin entirely.
