Discoal
Brakes On 205
Discoal
hey, im looking in too convert my standard 205 brakes too gti6 ones, disc and calappiers.
Any one have any tips on how too do it or what the best parts to use?
been told about fitting a spacer kit but not sure if that will be safe or not?
cheers too anyone that can help
If you have a 1.9 car to start with, the discs and calipers will bolt straight on. You may need a longer flexi hose, and ideally a different master cylinder, but that is it.
Have you tried a search as there is lots of info on this forum to help you.
platty
You'll need some longer brake lines, obviously disc's, calipers, and pads. Caliper bolts from a 1.9, and ideally a 406 non ABS master cylinder to reduce pedal travel.
Pitcrew member Miles can supply you with the brake lines.
Edit: Ah, Tom beat me to it.
Edited by platty
Discoal
Nice one cheers for the info big help just got start saving :rolleyes:
Sounds like it be easy enough getting hold of the part's cheers guy's
Discoal
Just looked on that link, think i should start useing this forum better!!
