Dj_mini
Alloy Mounts
Dj_mini
Im hoping some one can help im looking to make some brackets to hold some calipers on and im un sure what grade of alloy to use there seems to be a wide range? Can some one point me in the right dirrection to somthing that wont be ott and cost the earth as it just needs to be up to the job and tap well?
Cheers Dan
EdCherry
http://www.matweb.com/
Cant help you with a specific number/name as havn't looked in to it myself, you really need to work out the stress its going through/forces acting upon it to make it nice and safe.
Rippthrough
Depends entirely upon the size and shape of the mount, you need to know the stresses and work back to the most appropriate match from there, you'll prbably find 6082 T6 will be fine if you've got the room for enough thickness and a fairly stubby mount, and chamfered edges to knock stress risers down a bit.
But, it's holding your brakes on at the end of the day...you need to work it out.
Edited by Rippthrough
