Cloverleaf
406 Brembo Rebuild Parts
Cloverleaf
I've searched the forum but only found some old questions asking a similar thing, unfortunately none really have answers!
So where can you get seals and bleed nipples from? Do Peugeot stock them?
Someone previously suggested bigred for seals but I contacted them and they said I would need to send them my seal to match it. I'm a little worried about doing this incase it gets lost as at the moment the seal is useable but starting to look a bit tired.
Thanks,
Joe
Cloverleaf
Surely someone on here has purchased a bleed nipple at least!?
Guest flatout
a enginnering tools suplier should have some or www.pirtek.co.uk try these thay have stuff like these but thay aint the cheapest on the market but thay will have them and thay have stores all over the uk
EdCherry
Bigredd
Posted before, they can do anything for you.
ablister
peugeot only sell the piston seal kits as spares. They come in a peugeot packet but the box inside is genuine brembo as is the instruction sheet supplied. Worth it just for the instructions as it tells you how to overhaul the calipers as i couldn't find anywhere on the net that does.
Ebay sell bleed nipples but not sure what they're like
Cloverleaf
Thanks, can you remember how much?? Seems to me like there isn't a lot of availability for spares.
ablister
were around £15 for each kit (1 kit contains 4 seals for 1 caliper). Took a while to arrive as they were on back order. Can't remember part number but wil find it for you
Cloverleaf
Cheers mate :wub:
