AdamP
Is My Head Scrap?
AdamP
Just been stripping down my XSI head and found this:
It's pretty nasty on the cam but not so bad in the head. What damage would be caused if I ran it like that? Can it be repaired? I probably won't use the cam, what would happen if I ran a new cam in there?
Adam
Sandy
Difficult to tell from pics, but it might be honeable.
AdamP
Cheers :rolleyes: What would make it 'unhoneable', how bad would it need to be?
Sandy
If it goes oversize before a decent surface is achieved.
AdamP
So it's worth giving honing a go then, if its scrap its scrap either way!
oli-pug
Sandy- I've got this problem with my gti-6 head, although I've also got pick-up in the lifter bores too. Somehow, 3 of the snap clips in the lifters on the inlet have broken and worked there way out :lol: Have you ever seen this happen before?
Sandy
It's definitely worth a go Adam!
Oli, you can do the same on the 6 head and possibly the lifter bores, although lifter damage invariably means scrap on these. I've known various lifter issues on the 6, but not that one until now! Unless it's a head that's had good porting etc invested in it, I would consider getting a tidier one. If it was a customer engine I would unless the head was particularly valuable.
