omega
Ignition Lock Removal
omega
got a new ignition lock to fit removed the bolt and got the key in postion" a "as stated in the haynes,then it says push in plunger to remove as shown in photo but theres no photo!!so where is the plunger as i cant see it
Edited by omega
its a small pin on the side of the barrel, press it and turn the key till it will go in, then pull it out with the key.
omega
thanks mate the secret is to turn the key [not in the haynes book]then it comes out
Goliath
There is a small arrow or mark between positions A and B (I think its A-:blush:, the key needs to be lined up with that and then the positioning lug will press down and you can remove the whole barrel.
Phil H
...and don't forget to take out the grub screw on top !!!
