buster205
Best Rear Shocks For Road Use
buster205
mot due next month and rear shocks leaking oil ! read posts saying avoid the ones from streetline kit, which should i go for ?
Ste
bouver
I dont thnk you can go far wrong with koni's. i think there are some on e bay at the monent to if you dont have the coin for new ones.
standard dampers, which IIRC are part number 5206 K6 :ph34r:
Standard genuine 306 GTi-6 dampers work well and are cheap, or Bilstein Sprintline/Sport (yellow) dampers work well and aren't too expensive.
As you've correctly identified, avoid the Bilstein Streetline/"OE" (black) rear dampers as they're woefully underdamped...
allanallen
if your on a budget try some 306 gti6 ones, I've been running a second hand set on mine for a while and really rate them
that's the part number I quoted :ph34r: happens to be the part number for the 1.9 205 too....
Edited by welshpug
buster205
spoke to rob from autofive he says he can do the bilstein rears from the sprintline kit as seperate items. he says prices are going to be revised so not sure how much they come out at. who make the standard oe gti6 rears ?
Peugeot. From memory, they're about £35 each new, and that's for genuine OE parts from the dealer.
buster205
cheers Anthony at that price i'll go for them !
the Bilstein ones used to be around the £96, EACH.
wouldn't be the best choice for standard torsion bars IMO.
The Sprint/Sport ones are fine for standard TB's in my experience, as are the softer Group N ones (Gravel/Forest?).
Group N Tarmac and the Challenge spec dampers are a bit OTT for standard TB's on the road though
buster205
would there be any problems with having sprint/sport dampers on rear and bilstein oe (streetline spec) on front, fronts were fitted by previous owner along with apex -30mm springs. i had rear beam refurbed at skip browns about 18 months ago with group n rear beam mounts fitted.
mattmalden
So Welshpug are you saying that the 306 gti6 and 205 1.9gti use the same rear dampers?
Seems a bit wierd that people go on about how good the 306 ones are if they are the same part..
:blush:
that's the part number I quoted :blush: happens to be the part number for the 1.9 205 too....
They are the same part number these days, but they're not the same, certainly weren't from std and are visibly different too. What i suspect id that they're dropped the 205 ones and just use the same part number for the Gti6 ones...
AdamP
:blush:
They haven't always been listed the same. They've changed recently I think! I checked just now on servicebox and they are listed as for XU9JA engines 205s from a certain chassis number and are priced at £45.34 each including VAT.
buster205
demon tweeks do koni sport rears at £149/pair inc vat, look decent value at that !
Ste
jengis
I have 306 2.0 rear dampers (the genuine pug "K6" part number, same for XSi, S16 and GTi-6 etc.) and I think they are perfect for standard beam. I think it is the quality of the bushes that makes them quite comfortable with nice stiff bound damping to give sharp high speed handling. Often so callled uprated sport dampers have poly bushes and quite weak bound damping, designed for stiffer bars and not ideal for the road in my opinion. And poly bushes in rear dampers won't last long either, my AVO adjustables are crap!
Up front I have yellow bilsteins - stiff but great! I never liked the oe (black/streetline) bilsteins, even the fronts. The ones I had on the 306 had a solid top-out that clunked loudly. I didn't like the damping very much either, bit I never tried them on the 205. As everyone says, don't get black oe bilstein rears - unless you want a back end like a trampoline!
I hear people talking about gravel spec or tarmac spec bilsteins, group N etc. Does anyone know if my "B6" struts are gravel or tarmac spec, or is that just for coil-overs? Are the inserts the same?
Edited by jengis
buster205
anyone fitted koni sport rears ? seem good value ! are they suitable for road use or overly stiff ?
buster205
just fitted new rears 5206 k6 from dealers, they came in usual dealer packaging, only branding i could find was on the top mount bushes and were marked BOGE
cheers for all the replies !
Ste
I have them along with the fronts on one of mine, it's good, stiffer yes but not overly.
JayCC
my local dealer wanted £46each for the K6, that seems expensive. That about right?
sounds about for an inc vat not discounted price yep :o
kilauea
As an alternative choice, I have KYB AGX adjustables and I find them spot on.
They're £37 + vat for rears.
I used to have some Koni yellow adjustables on mine (still got them on the front) & they were harsher than the Bilstein group N tarmac shocks I replaced them with when one sprung a leak but I've driven other 205's with the same Koni shocks & they were much more compliant.
If you are at all worried about ride comfort then get the K6's from Peugeot.
Graham.
tagy
Has anyone tried the KYB AGX front adjustables? I noticed buypartsby.com sell them quite cheap.
On the rear I liked the AVO adjustables I used to have, as they seemed to have a big range from soft to pretty hard.
