Guest flatout
S16 Ecu Diagram
Guest flatout
i have run a search and i have had no luck . i need a s16 ecu wiring diagram. i have found every ecu but mine the colours and numbers dont seem to mach up i think the closest i got was a 605 diagram but im not to sure about that one please can any one help its the only thing thats stopping me do the conversion and im itching to compleat it so i can wright a topic on the whole build . thanks
This topic might help.
I attached the pages from the Haynes manual for the S16 engine as fitted in a Citroen ZX in one of my replies.
Graham.
Guest flatout
i had a look at this topic and the wiring just dont mach up to my loom and ecu for some use but me and my dad think we may have sorted it out now hopefully .
jimbean
hello there
the 605 wiring is a good start.... the wire numbers will ne different but the main lives and earths to the ecu will be cock on...
i did the same conversion on 1 of my customers cars about 1 year ago
i used a mp3.2 8v turbo loom with a 3.2 s16 ecu on a gti6 engine.... thats about as hybrid as it can get
i used the 605 ma3.2 turbo wiring diagram
you will need to use a multimeter and start at the ecu plug and work backwards to the engine harness plug and double relay
Guest flatout
hello there
yes i have found the 605 wiring is the closest im goning to get to the 306 s16 so im going with that . i only need a few wires any way eg: ignition , battrey and fusebox so shouldnt be that hard . i will take pictures at the weekend if the wether is ok . thanks for the help everybody very much appreciated.
