Cameron
Phase 2 Rear Cluster Layout
Cameron
I've dug out my old phase 2 clusters and am going to fit them to my P1.5, but its been ages since I saw them in use and I can't tell which bulb is which. :)
Could somebody just clarify for me?
From what I've guessed. the lower left one is the indicator, the lower right one is the fog light, the upper ones are brake and tail lights (but I don't know which is which). Its an offside cluster by the way.
Thanks in advance.
platty
Top two are side lights, Lower left is brake, lower right is indicator. Fog light goes in the rear valence :)
Edited by platty
Cameron
Really? I thought the reverse was in the valence and fogs in the cluster. Good job I didn't try and wire it up. :)
platty
Yep, reverse is down in the valence too :)
thirdtimelucky
As Platty said. I used a phase 2 rear wiring loom to make the job easier and origonal looking to convert my phase 1.5 it plugs stright into the fuse box. although Ive seen the photos of the looms that you have made, very neet.
Paul
Cameron
Thanks for the info guys. :D
Cameron
Aha, that should help things a little. :D
